Internal calls between two VG224 without CUCM
alimurtazo
I have two Vg224. And i use it only internal calls without CUCM. One of them 100,101....123, and another one 200,201,...213. Its working fine in own side. But i can not call from vg1 to vg2.
How to solve this issue?
Please, help!
2 Accepted Solutions
So you are trying to call b/w two VG's over IP right ? You need a VoIP dial-peer on each VG pointing to the other one -
dial-peer voice 1 voip
destination-pattern XXXX
session target ipv4:Y.Y.Y.Y
codec g711ulaw
no vad
You can tweak the codec if need be. Since this is on your LAN, it should work fine.
Great job!
Its working.
Thank you for support!
6 Replies 6
R0g22
Are these VG's registered to CUCM either as SCCP or MGCP ? Do you have a log from either VG or CCM trace to look into ?
No. Its not connected CUCM. Both Vg224 connected each other by LAN cable.
What are you using , H.323 or SIP ? Share the configs please.
I used these commands.
write erase
reload
! after reload
conf term
hostname rtr_201
interface FastEthernet0/0
ip address 10.22.33.201 255.255.255.0
dial-peer voice 20 pots
destination-pattern 200
port 2/0
dial-peer voice 21 pots
destination-pattern 201
port 2/1
end
this is my config.
In the attachment vg224 config.
codec g711ulaw
no vad
Great job!
Its working.
