IP Phone 7811 not register on CME 12
donathien
*May 13 09:15:34.889: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/sipSPIGetRejectedRequestSyslog: Syslog Timer re-started for silent discard
*May 13 09:18:25.373: TFTP: Server request for port 53083, socket_id 0x3EF49B6C for process 162
*May 13 09:18:25.373: TFTP: read request from host 172.16.61.10(53083) via GigabitEthernet0/0.61
*May 13 09:18:25.373: TFTP: Looking for 7811-3PCC.xml
*May 13 09:18:25.373: TFTP: Sending error 1 No such file
*May 13 09:18:25.409: TFTP: Server request for port 50585, socket_id 0x3EF49B6C for process 162
*May 13 09:18:25.409: TFTP: read request from host 172.16.61.10(50585) via GigabitEthernet0/0.61
*May 13 09:18:25.409: TFTP: Looking for Cisco/CP-7811-3PCC/50f7222d7f6f.cfg
*May 13 09:18:25.409: TFTP: Sending error 1 No such file
*May 13 09:26:25.705: TFTP: Server request for port 51610, socket_id 0x3EF49B6C for process 162
*May 13 09:26:25.705: TFTP: read request from host 172.16.61.10(51610) via GigabitEthernet0/0.61
*May 13 09:26:25.705: TFTP: Looking for 7811-3PCC.xml
*May 13 09:26:25.705: TFTP: Sending error 1 No such file
*May 13 09:26:25.741: TFTP: Server request for port 51444, socket_id 0x3EF49B6C for process 162
*May 13 09:26:25.741: TFTP: read request from host 172.16.61.10(51444) via GigabitEthernet0/0.61
*May 13 09:26:25.741: TFTP: Looking for Cisco/CP-7811-3PCC/50f7222d7f6f.cfg
*May 13 09:26:25.745: TFTP: Sending error 1 No!        e
R0g22
That's a 3PCC/MPP firmware based 78XX. You need to have a enterprise firmware based phone.
Hi there
Following Nipun's posts, you need a CP-7811-3PCC-K9= to work with this firmware.
If your phone is CP-7811-K9= phone you need cmterm-78xx.10-3-1-12 or later
Installing Cisco Unified CME Software
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/manual/cmeadm/cmeinstl.html#concept_D4C49462CEEC4B388758656C01DCBD54
Hope this helps!
Cheers
Rath!
***Please rate helpful posts***
