ISDN Problem
lfplaimer
Hi all,
I have a AS5350 and recently I updated the IOS from 12.3 to 12.4.
The configuration didnt changed, but in the 12.4, the calls are disconected with the code(service or option not available, unspecified (63)).
I turn the ISDN debug on and this is what I got.
If I rollback to 12.3 everything works fine.
Please help.
Best regards.
Luis Laimer
This is the output from the debug isdn q931.
Dec 23 16:18:09.780: ISDN Dc3/2 SC Q931: RX <- SETUP pd = 8  callref = 0x0049
        Bearer Capability i = 0x9090A2
                Standard = CCITT
                Transfer Capability = 3.1kHz Audio
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xE982839F
                Exclusive, Interface 2, Channel 31
        Facility i = 0x9E8100036774640000002E49414D2C0D0A4743492C65643330616139396630613731316465613761313030303362616563393539640D0A0D0A
        Progress Ind i = 0x8183 - Origination address is non-ISDN
        Calling Party Number i = 0x2181, '5132013022'
                Plan:ISDN, Type:National
        Called Party Number i = 0xA1, '0212730760333'
Dec 23 16:18:09.992: ISDN Dc3/2 SC Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8049
        Cause i = 0x80B9 - Bearer capability not presently authorized
pratik.rb
Level 3
Level 3
Can you post a successful call debug output on 12.3 IOS.
Also, did you try putting the command bearer capability speech under voice-port then shut no shut.
Hi Pratik,
Thanks for your reply on this. I belive that theres some issue related with the configuration that is in place with the 12.3 and 12.4.
Will the same conf file work for both versions ?
I took a debug isdn q931 with the 12.3:
Dec 28 11:32:56.785: ISDN Dc3/2 SC Q931: RX <- SETUP pd = 8  callref = 0x0006
                Standard = CCITT
        Facility i = 0x9E8100036774640000002E49414D2C0D0A4743492C65393166376635616634366431316465626362313030303362616563393539640D0A0D0A
        Called Party Number i = 0xA1, '0212730762998'
Dec 28 11:32:56.797: ISDN Dc3/2 SC Q931: TX -> CALL_PROC pd = 8  callref = 0x8006
Dec 28 11:32:57.894: %SEC-6-IPACCESSLOGP: list 101 permitted udp 200.229.119.91(5060) -> 189.14.192.115(5060), 5 packets
Dec 28 11:32:58.302: ISDN Dc3/2 SC Q931: TX -> CONNECT pd = 8  callref = 0x8006
Dec 28 11:32:58.354: ISDN Dc3/2 SC Q931: RX <- CONNECT_ACK pd = 8  callref = 0x0006
Dec 28 11:33:09.674: ISDN Dc3/2 SC Q931: RX <- DISCONNECT pd = 8  callref = 0x0006
        Cause i = 0x8590 - Normal call clearing
Dec 28 11:33:09.674: ISDN Dc3/2 SC Q931: TX -> RELEASE pd = 8  callref = 0x8006
Dec 28 11:33:09.722: ISDN Dc3/2 SC Q931: RX <- RELEASE_COMP pd = 8  callref = 0x0006
As you can see, it works fine when the version of the IOS is the 12.3.
Ill test your procedure and see if anything changes.
Best regards
Luis Laimer
When I dial the same number, with the same conf, in the 12.4 the debug shows:
Dec 28 12:04:49.359: ISDN Dc3/2 SC Q931: RX <- SETUP pd = 8  callref = 0x0008
                Standard = CCITT
        Facility i = 0x9E8100036774640000002E49414D2C0D0A4743492C35643132343164366634373231316465393666313030303362616563393539640D0A0D0A
Dec 28 12:04:49.367: ISDN Dc3/2 SC Q931: TX -> CALL_PROC pd = 8  callref = 0x8008
Dec 28 12:04:49.367: ISDN Dc3/2 SC Q931: TX -> DISCONNECT pd = 8  callref = 0x8008
        Cause i = 0x80AC - Requested circuit/channel not available
Dec 28 12:04:49.499: ISDN Dc3/2 SC Q931: RX <- RELEASE pd = 8  callref = 0x0008
Dec 28 12:04:49.499: ISDN Dc3/2 SC Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8008
Dec 28 12:04:56.188: ISDN Dc3/2 SC Q931: RX <- GROUP SERVICE pd = 67  callref = 0x0000
        Interface Service i = 0x02FFFEFFFE
Dec 28 12:04:56.188: ISDN Dc3/2 SC Q931: TX -> GROUP SERVICE ACK pd = 67  callref = 0x8000
Best Regards
Luis Laimer
I also configured the bearer-capability speech as follows:
voice-port 3/2:D
echo-cancel coverage 32
cptone BR
timeouts initial 15
timeouts interdigit 7
bearer-cap Speech
and the Controller E1 is configured like:
controller E1 3/2
framing NO-CRC4
channel-group 15 timeslots 16
pri-group timeslots 1-15,17-31 nfas_d primary nfas_int 2 nfas_group 2 rlm-group 2
description EMBRATEL - INTERCONEXAO STFC - DPC 6113
interface Serial3/2:15
no ip address
encapsulation ss7
channel-id 2
Still getting the same problem.
Best Regards
Luis Laimer
