need mib under AS5400HPX platform
mbasalp
Hi all,
I need to define incoming and outgoing calls per e1 separately under AS5400HPX platform using related mibs. But i could not find anything in the mib locator about that.
Is there anybody who did succeed in this job before ?
Thanks in advance.
j-block
Level 4
Level 4
DIAL-CONTROL-MIB should be able to provide that
Look in SNMP Object Navigator for cpmDS1ActiveDS0s
Is the number of DS0s that are currently in use for a
particular DS1.
result 1.3.6.1.4.1.9.10.19.1.1.9.1.3
I have an As5350 and I'm using this:
# cpu & calls e1/0
1.3.6.1.4.1.9.9.109.1.1.1.1.8.1&1.3.6.1.4.1.9.10.19.1.1.9.1.3.3.0
# cpu & calls e1/1
1.3.6.1.4.1.9.9.109.1.1.1.1.8.1&1.3.6.1.4.1.9.10.19.1.1.9.1.3.3.1
and so on...
i do it the same and it's working fine.
don't forget snmp configuration on your AS. this should do it:
snmp-server view XXX cpmDS1ActiveDS0s included
./regards
