08-01-2013 06:46 AM
Hi Everyone,
I have a few required QoS settings for a Voice system between two buildings being routed. (static)
I have QoS training coming up but, I just need to know what I have to have to put the basic QoS settings on each edge switch
with Static routes between.
I need to get the two phone systems on 2 different subnets to talk efficiently.
Just an open discussion with best practice and QoS basics would be a great step for me.
Thanks all
08-09-2013 07:42 AM
There is no need for QoS on LANs.
08-14-2013 02:27 PM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
For VoIP, what your normally want to do is insure the bearer traffic (the actual voice portion) gets first priority to your interface's resources (bandwidth and buffers). Voice signaling should be insured it's not excessively delayed and drops are avoided. For QoS to guarantee this type of service for these two types of VoIP traffic, you need to insure there's sufficient bandwidth. (Remember QoS allows interface resource management, it doesn't create bandwidth.)
PS:
Paolo says you don't need QoS on LANs. Well often that's true, as LANs generally have more bandwidth than WANs, but LAN interfaces can congest too. When they do, either you'll need more bandwidth (which often can be a viable solution for LAN) or you need QoS to manage your interface resources. I.e. sometimes QoS is very critical to meeting application service level requirements.
