VoIP & AutoQoS & frame/atm
ciscosupport99
I have 2 remote locations connected via frame/atm links currently with no QoS configs and potentially running VoIP. Is AutoQoS the simpliest and/or best solution, for voip communication across the WAN(frame/atm) if no other QoS is required ?
Thanks for your consideration -
paolo bevilacqua
No, I would recommend you manually configure QoS only after you have determined there is an actual need for it.
Joseph W. Doherty
" Is AutoQoS the simpliest and/or best solution, for voip communication across the WAN(frame/atm) if no other QoS is required ? "
"Simpliest", probably yes, "best", probably not.
For a fixed bandwidth inteface, such as a LAN port or WAN dedicated p-2-p port, a very simple QoS that prioritizes VoIP payload packets and guarantees bandwidth for signally packets, might be fine, but FR/ATM/MPLS WAN circuits often have other issues that AutoQoS won't likely deal with.
I'll admit that I haven't used AutoQoS on a WAN link, and definitely not on a FR/ATM interface.
I normally associate appropriate use of the AutoQoS command with L2 switchports, since the queueing on the switches is much more complex.
For routers, it's very simple, and there is a wider variance in how people use it.
In a very bare-bones scenario, you can get away with this:
class-map match-all voice
match protocol rtp audio
policy-map LLQ
class voice
priority percent 50
class class-default
fair-queue
int s0/0
service-policy out LLQ
You could make it more well rounded by matching on your VoIP signaling and other high priority traffic, but that's specific to your needs.
-nick
