VOIP calls not being forwarded from GW to GK and visa versa
melhajj123
I have a VOIP network setup in place using 2691 routers. i have a siemens PBX connected to the 2691 routers using an E1 controller (running QSIG), my WAN interface between the two sides is an ATM interface. when i do a csim start from one router to the extension on the other side the call goes through and the phone rings. However, when i actually dial from one extension to the other, the call is not being forwarded. and what happens is that i hear the dial tone again on the phone im dialing from.
I have taken some debugs but still could pin point the problem, even though in the ccapi inout debug i found that when it tries to look for a node, it doesnt find it.
I have attached the configuration for both sides. Along with the debug from one of the sites.
There are a couple of GW's associated with the GK.
The ones im concerned about are Mussalla_GW & GK-HO.
Thank You in advance
Mouhannad
melhajj123
the ccapi debug
dgahm
Level 8
Level 8
Try this:
dial-peer voice 2 pots
direct-inward-dial
Without this command the router will not collect the digits coming across the PRI.
Please rate helpful posts.
Thank You very much for your help, this solved the problem.
How did i miss such a thing
