VoIP Network Design
Dan Torres
Hi everyone,
I’m seeking advice in designing voip network. Is there any reason to stick with the following:
1. one network
2. one Ethernet cable run to each cubicle for both data and voice
3. setup QoS on a router/firewall
When we can run two Ethernet cables to each cubicle (one for data and another one for voip)?  There will be two networks and QoS wouldn’t be setup on the phone network (it will be used just for voip traffic)
paolo bevilacqua
If using own cable, QoS is not a problem at all, and there is no reason to worry about it.
thank you for the reply. do you know if it possible to setup QoS for phones when i have port based vlan setup?
As above, no need to worry abot QoS on LAN.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Just to clarify, when you write of running two cables to each cubicle, one for data and one for VoIP, the two sets of traffic never share a link (or device)?  For example, both those links wouldn't terminate on the same device?
If any part of the network infrastructure shares physical resources with both the data and VoIP traffic, there's a chance the data traffic might be adverse to VoIP.  If there's any physical resource sharing, QoS might be configured to guarantee resources to VoIP traffic over data traffic.
As LANs often have ample bandwidth, and it's often easy to provide more bandwidth, if necessary, you might not need to utilize QoS to have acceptable VoIP.
PS:
BTW, older hosts used to have TCP stacks that would cap their bandwidth utilization on high speed LANs.  Newer TCP host stacks can often drive even 10g host links at full utilization.  QoS might be needed where it didn't used to be needed.
