12-10-2004 09:16 AM
I'm trying to map a VoIP call to a specific timeslot in a ISDN PRI E1. My hardware is a 5400HPX. Does anybody know how to do this ? I'm receiving VoIP calls in the 5400HPX, and I then forward them with a dial-peer to a E1 ISDN PRI (configured with pri-group). What I want to do is to forward the call through the PRI, through a specific timeslot I can configure.
Marcos
12-13-2004 03:26 AM
I do not know the 5400HPX but i think it is also IOS based.
Check out the following link. under isdn service you will find how to change the state of certain b channels.
Hope that helps
Roger
12-21-2004 08:42 PM
It's not possible to map calls to specific B channels. The software does not have this feature. The only way you can do this is with E1 or T1 CAS and use individual DS0 groups for each timeslot - this creates a specific voice port per timeslot.
