6851 expansion module
Hi there,
side panel for cisco 6851 seems not working properly. after upgrading to version sip68xx.11-2-3MSR1-1 all buttons become orange instead of green
my configuration is like this:
fnc=sd+blf;sub=xxxxx@$PROXY;nme=anyname
I tested with both Asterisk and Broadsoft server type but no success (light solid orange).
But configuring as: fnc=sd+blf;ext=xxxxx@$PROXY;nme=anyname
works only as speed dial (light solid green)
Any help ?
Geovani
Hi there,
Are you still having issues with this?
Geovani
Actually I haven't tested again as I replaced it by 8841 and configured the buttons as BLF and it worked. So it could something wrong with the expansion module as the phone worked without it.
It might be indeed a fault with the KEM.
Try using 11.3.1 and see if it makes any difference.
