07-16-2009 05:38 PM - edited 03-21-2019 01:19 AM
I have looked, and from what i can tell you cannot modify the background image on a 7925g as you can the toher 79xx series (most likely excluding the 7920 also). i just wanted to try and find a difinitive answer so i can stop looking.
Solved! Go to Solution.
07-16-2009 08:05 PM
This is not supported on the 7925 when deployed with UC500. The latest versions of UCM (Call manager) do offer this support, but not UCME.
Marcos
07-16-2009 08:05 PM
Marcos
