Using SPA9000 and SPA 9x1/2 IP phones, what is the priority of the dial plans that can be set in each device? Should the IP phone have something like (xx.) in the active line(s) and have the rest done by the 9000?I do not see a comment on this in the...
I have a recpetionist phone, a 524sg, and while on a call there is a choice to put the call on hold. When a second call to the same number comes in the choices change to only 'answer'. When she clicks answer the other call is disconnected.How can we ...
Hello!I have a partner in the DTV business who complain that the SPA2102 bugs their multicast transmissions through sending a ethernet PAUSE fram when receiving multicast in a rate it cannot handle although the SPA2102 is not (or at least should not)...
HiI'm also interested on a firmware update that will allow the SPA941 to authenticate through the LDAP.Is there a way to do it?As a University we have plenty of those SIP Phones that we can't use.p.sOur Call Manager isCisco Unified CM AdministrationS...
Hello,I want to use the auto attendand to transfer calls without voice messages, based on time slots. For example, daytime script transfer to 402, nightime script transfer to 403.If I use the script<aa><form id="dir" type="node"><audio src="prompt1" ...
I have mucked up my system to the point where I need to rebuild it ... but after many, many hours I've not had any luck figuring it out myself. I've looked through most of the "restore from default" type posts, but still can't make it happen.I can st...
Hi,Just wondering if there are any plans to add PPTP Client Support to the WRP400 Like the WRT54G3G has for the USB Modem Connectivity in future releases?Thanks,David
I have a client with a UC520, would like to have a small site with 3 phones to share phone system.Currently they have a point-to-point between the two sites. I set the main ste up already for 4 digits.Can someone please point me in the right directi...
I have problem with transferred calls...Incoming calls --> SPA 9000 --> SPA 400 --> to announce --> BXFER to IP phones --> SNOM M3 --> after 30s calls automatically finish.
My current AA will detect fax signalling and automatically forward the call to the extension that I designate that has a fax machine on it.How do I do this with my UC520 and CCA 1.9?Thank You!Matthew Castrigno
Hello everyone,Is there any way to remove details from a voicemail left? When listening to a voicemail is takes forever due to the date/time/number stamp played prior to the voceimail itself.Thanks in advance!
Hello,In a VOIP installation with SPA9000 and SPA9XX phones I would like to setup a phone configuration repository.Doing this standard configuration will be uploaded to all phones.Any sugestion in this?Agim
I am a relative newb to the UC500 system so forgive me if this question has already been posted, I tried to do a search but couldn't find any relavent documents. Anywho, I recently downloaded and installed the 7.1 early release pack. Everything runs ...
Hi ,I have a customer with two sites.The main site will have the UC500 ... in the remote site they are having two IP handsets, which is easy enough.At the remote site the customer has two PSTN lines.Can we use an ATA with FXO or a small gateway to co...
