You may select the button as COline under the phone configuration.
Also at the begining of the Telephony Setup Wizard you may choose the system mode - PBX and Key system. You should choose key system to seize the PSTN lines directly.
For more information on this you may look at the CCA 3.2.1 Admin Guide p.278.
HTH,
Alex
*Please rate helpful posts
