08-08-2012 09:19 AM - edited 03-21-2019 06:08 AM
Hi there,
Customer wants all calls to main DID to go to a prompt and automatically transfer to a blast group. Is there an easy way to do this minus BACD?
Thanks!
HelpDesk
Solved! Go to Solution.
08-08-2012 09:33 AM
You could have the incoming calls sent to an AutoAttendant. Set the prompt to play once, and then transfer to the blast group number.
Thank you,
Darren
08-08-2012 04:23 PM
Hi Help Desk,
Like Darren has pointed out, you will need to use the AA kind of like an announcement server, a little unorthodox but it should work
So basically you will need to point the DID to the AA (Pilot number of the AA), create your recording for it I.E "Thank you for calling XYZ company, please wait while we transfer for your call", and in CCA you set it to play once and then transfer to the operators extension, in most cases this will be the reception desk or a blast group.
Now keep in mind, if your site is a busy incoming site and you have a PRI/ISDN service that has more than 12 lines, you need to factor in how many sessions the CUE can handle, which is where the AA resides.
Good Luck
Cheers,
David Trad.
08-09-2012 10:58 AM
Yes, that should work as you have it listed. I tested it in my lab, and it worked fine, calling the 1st AA from an internal extension.
Thank you,
Darren
08-08-2012 09:33 AM
Thank you,
Darren
08-08-2012 04:23 PM
Hi Help Desk,
Good Luck
Cheers,
David Trad.
08-09-2012 09:55 AM
Do you think it would be possible to have it do the following:
AA plays transfers to blast group, if no answer, go to second AA, Option 1 to leave a voicemail and option 2 for the blast group again.
In this situation, the voicemail is that of the original blast group.
So if I changed the final destination on the blast group to the new AA and make option on to leave a voicemail call 6+Blast group to go directly to voicemail.
In theory, I think it would work just fine.
Does this make sense?
08-09-2012 10:58 AM
Thank you,
Darren
08-09-2012 06:38 PM
Hi Help Desk,
To expand a little further on what Darren was saying, I just did a rebuild of a UC-520 on Monday night and needed to do the same as what you are trying to achieve, and I did it using the following method.
This method seems to be working very well and the client is very happy with it, yes there is no hold music when doing it, but this is a limitation of the system which has been clearly outlined to the client to set their expectations correctly, whilst we could use a B-ACD (Hunt Group) to achieve the on-hold music, it is not what they wanted.
I dont know if the above method would help, but it is the work around I have discovered and at least know I can use this methodology in the future for other sites
Cheers,
David Trad.
