Blank IP in CCA???
chris parkinson
We have a UC560, when I connect via CCA and try to view the IPs, I get the table showing the Interfaces & VLANs, but the IP cells are all empty???
I get the same result if I look at Config->Routing->IP_addresses, or Config->Switching->VLANs
If I login to the UC560 via the com port, I can do a show ip int br, and see the IPs.
Interface                  IP-Address      OK? Method Status                Protocol
GigabitEthernet0/0         192.168.20.10   YES NVRAM  up                    down
In0/0                      10.1.10.2       YES TFTP   up                    up
GigabitEthernet0/1/0       unassigned      YES unset  up                    up
GigabitEthernet0/1/1       unassigned      YES unset  up                    down
GigabitEthernet0/1/2       unassigned      YES unset  down                  down
GigabitEthernet0/1/3       unassigned      YES unset  up                    up
Vlan1                      192.168.0.60    YES manual up                    up
Vlan90                     10.1.10.2       YES NVRAM  up                    up
Vlan100                    192.168.10.1    YES NVRAM  up                    up
NVI0                       192.168.20.10   YES unset  up                    up
So, why can CCA not see the IPs?
David Mowery
What version of CCA are you running?
CCA is 3.2(2)
Is it just IP addresses?  Are you able to see other defined information?
Fixed it.  I remembered that I enabled SNMP last week, I just disabled SNMP and everything is working again.
Go figure ????
