Broken Download for SPA 5XX Linux SPC tool
craigvanham
Hi Guys,
The  download for the latest SPA5XX Linux SPC tool is broken, the zip file returns unexpected end. Also the eariler version  of the SPC tool will not run on linux, I get a  segment fault when I exacute it. Appears to be the same problem  mentioned here https://supportforums.cisco.com/thread/2021768
Craig
rbordner
Hi Craig,
I'm checking with the SPA Phone team on the Linux SPC issue.
Question:  Can you confirm the SPC version and file name you downloaded?
I'll post an update once the issue is resolved.
Thanks for raising awareness to this issue.
Randy
Craig,
Can you please confirm the Linux Version you saw segment fault error on?
The test team just double checked the SIP SPC file(s)  and verified version linux v2.6.9-5  did not see the segment fault.
We are still testing other versions on Linux but if you could confirm your version we can target that directly and test.
Randy
I tried it on 2.6.9-101.ELsmp build, it was SPC tool packaged in ver 7.5.2b on the download site. I tried downloading the latest again and still get unzip errors.
hmm I wonder if it's because I am running 64bitLinux OS and the program was complied for 32Bit?
