Call from Analogue phone to SIP phone
kurmai
Hi all,
I have a UC520 and a 2691. The UC520 has a SIP phone (7940) registered, and the 2691 has an analogue phone connected to its FXS port. The two routers are connected through a crossover ethernet link. Since the SIP phone is registered, the UC520 has a dial peer for it. What should I do to let the analogue phone and the SIP phone call each other? Thanks!
Steven Smith
Level 7
Level 7
You will likely need to add a SIP dial peer for communications to and from the analogue phone on the 2691.  You will need dial peers on the 2691 also to accept and place calls to the UC500.
Thanks Steven. I had some issues with them calling each other, but it ended up to be codec.
