09-17-2013 02:28 AM - edited 03-21-2019 07:46 AM
I have a UC540 with an analogue PSTN line with caller ID activated on that line.
When I use a standard fixed telephone on the above PSTN line, I can see the number of the person who is calling me (Caller ID).
When I connect the same analogue PSTN line on my UC540, I always get 'anonimous'. I can't see the caller's number.
How can I fix this because the caller ID is important to me. On internet, I read that there are two protocols (DTMF and FSK) for caller ID on PSTN lines, but I can't find which protocol the Cisco UC540 is using. I have looked into the settings of the FXO ports on the Cisco UC540, but I can't find any information.
Can anybody help me?
PS: I'm from Belgium (Europe).
09-17-2013 11:03 AM
The protocol is automatically selected depending of the cptone configured under voice-port.
11-04-2013 01:42 AM
Add these lines to the voice port
voice-port 0/1/0
caller-id enable
caller-id alerting line-reversal
caller-id alerting dsp-pre-allocate
I had this issue with analogue line connected to my FXO port and the above resolved it.
Hope this helps you.
01-29-2014 08:02 AM
I found this gem to fix my caller-id issue.
Works like a charm.
I am using a GSM gateway and I only needed to add.
translation-profile incoming 4000
Thanks dude!
