06-20-2012 02:08 AM - edited 03-21-2019 05:56 AM
Good day all,
Please I need help on this. I have an E1 link on my UC 560 router with voice configured on it. But i want to use VoIP with my softphones. How do I configure VoIP on my router? I mean can I use VoIP with E1? And how do I go about configuring the router again? Please, I need urgent response.
06-20-2012 07:41 AM
I thikn you need to be more clear about what you are trying to achieve. UC560 is a VoIP system and softphones can be used just like normal IP phones, simply install Cisco IP communicator and set-up like any other phone.
If you mean you want to use a SIP provider, then that is of course possible too, but would depend on your Internet connection and how it's connected to the UC560. An E1 card is a VOICE interface, not IP.
You can use the WAN port to connect to an ethernet Internet link, or route via the LAN to an external router (like ADSL router).
06-23-2012 11:51 AM
You need to configure VPN for your remote users. There are many threads on the subject, you can search.
Alternatively you can hire a reputable/certfied Cisco partner to do that for you.
