Can UC560 support CP7926
hector torres
Looking to setup a UC560 in a manufacturing/warehouse environment and the CP7926 bar coding capabilities would be great; the product description states it works with Unified Communications Manager and not Manager-Express:
http://www.cisco.com/en/US/products/ps11266/index.html
Are there plans to allow 7926 to work with UC560 if it doesnt today?
thanks,
Hector
Darren DeCroock
Level 4
Level 4
Hello Hector,
I know that the latest version on CCA does NOT include the 7926, but the latest IOS does list the 7926.  So this phone should work, but would need to be configured using CLI.  Also, I do not believe that the bar coding capabilities would work as the UC560 is running Call Manager Express, and not Unified Communications Manager.  With the UC560, you would likely get phone capabilities only.
Thank you,
Darren
