Cannot register 9971 on UC520/CME 8.6
jyoopro4ia
I'm having issue registering a 9971 phone on a UC520 running CME 8.6
Here are the relevant configs -
voice register global
mode cme
source-address 10.1.1.1 port 5060
max-dn 224
max-pool 56
load 9971 sip9971.9-2-2
load 7971 term71.default
authenticate register
authenticate realm all
timezone 13
hold-alert
voicemail 400
tftp-path flash:
create profile sync 0467524178137401
camera
video
voice register dn  2
number 701
name Video Phone
no-reg
label Video Phone
voice register pool  2
id mac 8875.xxxx.xxxx
session-transport tcp
type 9971
number 1 dn 2
dtmf-relay rtp-nte
username video1 password 123456
codec g711ulaw
When I bootup my phone, it simply displays "Phone Not Registered".  If I manually set an Alternate TFTP and specify 10.1.1.1, it requires me to enter 123456 to enter Administrator Settings and I also see Extension Mobility and My Phone Apps under settings which is an indication that the phone system is talking to the phone.
Here's my debug tftp events output -
Oct  8 20:13:46.781: TFTP: Looking for CTLSEP887556511C12.tlv
Oct  8 20:13:46.873: TFTP: Looking for ITLSEP887556511C12.tlv
Oct  8 20:13:46.961: TFTP: Looking for ITLFile.tlv
Oct  8 20:13:47.089: TFTP: Looking for SEP887556511C12.cnf.xml
Oct  8 20:13:47.089: TFTP: Opened flash:/SEP887556511C12.cnf.xml, fd 1, size 4338 for process 336
Oct  8 20:13:47.117: TFTP: Finished flash:/SEP887556511C12.cnf.xml, time 00:00:00 for process 336
Oct  8 20:13:49.201: TFTP: Looking for featurePolicyDefault.xml
Oct  8 20:13:49.205: TFTP: Opened flash:/featurePolicyDefault.xml, fd 1, size 825 for process 336
Oct  8 20:13:49.213: TFTP: Finished flash:/featurePolicyDefault.xml, time 00:00:00 for process 336
Oct  8 20:13:49.477: TFTP: Looking for English_United_States/gd-sip.jar
Oct  8 20:13:49.577: TFTP: Looking for United_States/g4-tones.xml
When I look at the status messages on the phone -
Does not find United_States/g4-tones.xml
Does not find English_United_States/gd-sip.jar
Gets an error updating locale
Anyone have any ideas / suggestions?  Thanks!
bjames
Level 5
Level 5
I don't see the image in a tftp flash command (9951 in this example)
tftp-server flash:/phones/9951/dkern9951.100609R2-9-2-2.sebn alias dkern9951.100609R2-9-2-2.sebn
tftp-server flash:/phones/9951/kern9951.9-2-2.sebn alias kern9951.9-2-2.sebn
tftp-server flash:/phones/9951/rootfs9951.9-2-2.sebn alias rootfs9951.9-2-2.sebn
tftp-server flash:/phones/9951/sboot9951.031610R1-9-2-2.sebn alias sboot9951.031610R1-9-2-2.sebn
tftp-server flash:/phones/9951/sip9951.9-2-2.loads alias sip9951.9-2-2.loads
tftp-server flash:/phones/9951/skern9951.022809R2-9-2-2.sebn alias skern9951.022809R2-9-2-2.sebn
I still get the load errors on the phones but they work
Donwload and install new locale. This issue is related with the process:
CME SIP configured -> CME SIP removed -> CME SIP configured again
Verify the voice service voip configurations. The registrer server must be set on sip. Trust me, I spedn a lot of hours to discovery this. Afer I added the registrar command, the 9971 phone register quickly!
voice service voip
 no ip address trusted authenticate
 allow-connections sip to sip
  sip
  bind control source-interface VlanX
  bind media source-interface VlanX
  registrar server
The error with the locale always happens. I tryed to solvi it with defferente firmwares and locale versions, but I don't know why 9971 tryes to get the ring and jar files on the directory flash that doest exists. I tryed this steps, but didnt solve the error, and the 9971 had registered and worked!
copy tftp://x.x.x.x/CME-locale-xx_XX-Xxxxxx.tar flash:/its/
archive tar /xtract flash:/its/CME-locale-en_US-English-10.0.2.7.tar flash:/its/
Router(config-register-global)#user-locale US load CME-locale-en_US-English-10.0.2.7.tar
Router(config-register-global)#create profile
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/sip-ip-phone-software/113048-reg-9971ip-cucm.html
You saved me with the:
voice service voip
sip
registrar server
Thanks a lot
