Catalyst express UC520 series
uday kiran
Hi All,
I have a question regarding uc520 switch.
Can we use UC520 switch as a normal switch with linksys router(internet) connecting to UC520 Switch???
David Trad
Hi Uday,
Are you referring to the CE-520?
Or the new GE/FE-300/200 series switches?
Can you give the exact model number as it will help a lot
But for now I cannot see why not, the switches do not do anything special when plugged into a UC500 system, with the exception of the devices talking to each other to ensure smooth configuration... But they should also be able to work standalone as well.
Cheers,
David Trad.
davidtradconsultinggmail.com
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
