CFwDALL Not Passing CID INfo
RockstarWiFi
I have a couple new installs where the client wants all calls forwarded to an agent after hours, which we are doing, however the CID of course is coming from the Office, I need to be able to pass the CID information to that call, which I have done with PRI lines but have no idea how to do with FXO lines? Anyone have any idea's? Xlate patterns?
I appreciate the help!
8 Replies 8
Original caller ID for outbound calls is not possible on FXO. The CLID information is controlled by the CO provider, not the Cisco CPE.
Marcos
Marcos,
Is this possible with BRI?? The term is Call defelction I belive. We have other PBX´s that do the job, but I haven´t been able to enable this on the UC.
Eivind
Hi Eivind,
This should be possible on BRI, yes.
Marcos
Marcos,
Are you sure? Only documents I can find on the cisco web is that it´s only supported with PRI and QSIG. I´ve tried to open TAC case´s a couple of times with no luck. Please HELP :)
Eivind
Update:
I've found this documents:
http://www.ciscosystems.com/en/US/docs/voice_ip_comm/cucm/admin/7_1_2/ccmsys/a08procl.html#wp1156053
Message was edited by: Eivind Jonassen
If you mean passing the redirect number to the PSTN provider, that should be supported by any ISDN interface.
Marcos
I want the PSTN provider to "pull back" the call and redirect it, and then free up the B-channel from the BRI. This should only occur when a phone on the UC500 is set to "call forward all".
This is possible on Asterisk, NEC, Nortel and Alcatel to mention a few....
Eivind
You can do that by configuring a CO/Line, and by dialing the assigned "special Codes" from the telco...
I see now. If this is done with star codes, or "special codes" as it was mentioned, I will need to take a look at a Q931 trace for a "good call" to see what we can do on our side.
Marcos
