02-11-2015 08:18 AM - edited 03-21-2019 08:32 AM
Is there a way to mass delete Voicemails from the phone - we have over 100 new messages that we can't remove quickly and easily.
02-11-2015 01:36 PM
Hello alex00001111111111,
The SPA504G doesn't actually manage your VM, it is a client that is signing into the system that is managing your VM. Now depending on this System that is managing your VM if it does not give you an option to purge a mass amount of VM then you will have to go to the system that is managing your VM directly and see what options you have there.
If you do not have access to the VM system then unfortunately you will have to delete each VM 1 by 1.
Hope this helps,
Michael D.
03-03-2015 02:49 PM
I am following up to see if my post answered your question? If this post was helpful please rate or mark as correct. If you have additional questions please let us know.
Thank you,
Michael D.
