Configuration of 2 ISP with UC540
ppaul
I have two ISP. I would like to configure the UC540 to handle both the ISP. At present one ISP is connected to the WAN Port. We have converted one of the LAN port into a WAN port and connected it to the second ISP. How do I make 1 VLAN traffic to route over ISP 1 and the other VLAN traffic over ISP2.
- Peter
dominic lazure
how did you convert a lan port into a wan port?
i am trying to figure how to connect my sip trunk and my internet connection ( 2 routers ) if there is only 1 wan port....
thx
This could be done in CCA by adding a VLAN then assigning it to one of the LAN ports as an access port to that VLAN.
This is done under:
Switching -> VLANs
and
Switching -> Smartports
