cor list question
TY08
hi guys,
i have question regarding cor list or how to setup something like my case. i am trying to setup 2 companies with 1 uc 540. uc 540 has 1 pri and 4 pots lines, so company a will use only pri line, and company b will only use pots lines. so how can i accomplish such thing for inbound and outbound. for inbound, i am okay with but outbound whenever company b dial out, it will then automaticall pick up pri line. i have 2 set dial peer and pri has higher preference than pots line.
let me know if you guys ever encounter similar case to this and how to approach the solution.
thank you.
janickle
I would imagine that you could accomplish your goal by implementing 2 different steering digits say 8 for company A and 9 for company B.  Then create 2 trunk groups one for the PRI and another for the FXO ports.  Then you could add restrictions to each company to keep them from dialing the others steering digit or extensions.
I hope this gets you on the right path.
Jason Nickle
thanks Jason. i had that thoughts too, but if i do that way then i don't really need corlist, am i right? the reason i want to have cor list so that everything is the same. i tried to use the corlist concept based on cisco documentation and it's not working as i expected.
