CP 7937G resetting continuosly in registering UC560
CSCO10638083
Dear Sirs,
I’m trying to connect a CP-7937 conference Station in a UC 560. In this UC I’ve got several phones working correctly. When I configure the mac address previously in the UC, the unit gets IP, it loads the regional configuration, and after it resets. If I delete the extension and mac address of the CP-7937, it loads all the firmware, and stay without extension number but it doesn’t reset.
Could anyone get me some light int this issue?
Best regards,
Ferran Gil
Hi Ferran,
Please enter the following command into config mode and then restart the phone:
(config)# tftp-server flash:/its/user_define_4_rp-sccp.jar
HTH,
Alex
*Please rate all helpful posts
7 Replies 7
Hi Ferran,
Are you using non-US locale? If yes which one?
Could you post the output of the following command:
dir flash:/its | i .jar
Best regards,
Alex
Hi Alex,
I use the  UC500_8.6.0_locale_es_ES. I'll post the command output in a while.
Best regards,
Ferran
Hi Alex,
Here is the flash list:
248 -rw- 74890 Nov 20 2012 20:37:22 +01:00 user_define_4_gp-sccp.jar
250 -rw- 61655 Nov 20 2012 20:37:24 +01:00 user_define_4_mk-sccp.jar
254 -rw- 71724 Nov 20 2012 20:37:26 +01:00 user_define_4_tc-sccp.jar
251 -rw- 69843 Nov 20 2012 20:37:24 +01:00 user_define_4_rp-sccp.jar
245 -rw- 61858 Nov 20 2012 20:37:22 +01:00 user_define_4_be-sccp.jar
249 -rw- 61946 Nov 20 2012 20:37:24 +01:00 user_define_4_ipc-sccp.jar
255 -rw- 61946 Nov 20 2012 20:37:26 +01:00 user_define_4_td-sccp.jar
Best regards,
Ferran
Hi Ferran,
HTH,
Alex
Hi Alex,
The answer is correct!!!
It works fine, as other phones in the system.
Thank you very much!!.
Ferran Gil
Hi Ferran,
I am glad that the issue was resolved. Thank you for the feedback and the rating!
Best regards,
Alex
with this line I can registered my 7931 and all work fine.
