Voice Systems and Accessories - Small Business
Upgrade your communication system with our Voice Systems and Accessories, perfect for small businesses.
I'm attempting to setup an SPA8000 with a single trunk to an ITSP account that has multiple DIDs, and I need each DID to route to a specific line port on the SPA, but I can't seem to figure out how to set such inbound call routing.  Unfortunately, I ...
So I went in and changed a woman's last name after she was married and changed another user who was terminated to a whole new username.  Both names showed up correctly on the phones but it doesn't seem to be working on a global scale. When they are p...
I have a cisco UC320W and after 40 seconds of placing anyone on hold, we cannot resume the call. the cisco phone SPA 303 says trying to resume but never works and there is no way to resume call. Then call is dropped. Any help would be really apprecia...
Have SPA514G phones using firmware version 7.5.3. Line ID Mapping is set to Vertical First. First call comes into phone and rings 1st button (Call Appearance). Second call rings behind the 1st button instead of ringing 2nd button on set. It appears t...
Hi, Using a tftp server to provision these phones I insterted into the configuration  :    <!-- Language Dictionaries -->   <Dictionary_Server_Script ua="na">   serv=tftp://172.20.20.1/;   d0=English-US;x0=spa50x/spa50x_30x_en_v755.xml;   d1=French;x...
If you are having trouble opening CUCC on MAC please check these settings Under System Preference—> Security & Privacy—>General Tab—>Allow apps download from AnywhereI deleted the files and tried to download from the site that you did and this worked...
nalbert by Level 4
  • 585 Views
  • 0 replies
Hello all, I'm having issues with the call forwarding all feature on a UC540.  A user wants to set call forwarding all to an external number (their personal cell phone) so when an incoming call to their number connects, the system will forward the ca...
Hardware: SPA504G (I assume all SPA50x are affected), firmware 7.5.5 (seen on 7.5.4 as well).Configuration: XML Directory Service URL set to own phone directory application written in PHP. Such application use following XML object to ask user for inp...
Dan Lukes by VIP Alumni
  • 832 Views
  • 1 replies
We are experiencing problems with the CiscoIPPhoneInput object. The InputFlags field is set to "A". Whenever someone starts to fill in "No", it is automatically translated to "Nei", which obviously prevents them from searching for anything related to...
Hello.We fired our technology guy for stealing and he reset our Cisco UC540 and SonicWalls to factory default.Our environment was the following:WORK had a TZ205-W with 192.168.34.x and the UC540W was 192.168.34.3 on LAN only. We only need the UC540 f...
