04-09-2013 07:05 AM - edited 03-21-2019 07:12 AM
I would like to create a call blast with a single extension number but i's no possible. How can I get around this?
04-10-2013 04:29 AM
I can't for the life of me see the point in this, you could just assign another dn as an overlay or secondary number, but what you *could* do is:-
create a dummy ephone-dn (any number) and add this into the list of numbers? (siince you need a minimum of two this should work fine).
since it will not be assigned to any phone it will not cause any issue that I can see.
p.
04-17-2013 01:55 AM
Hi Pierrescotland
thanks you for your reply.
I solved this problem by adding a fake number (210) in "Other Number"
