CUE is in use most of the time on UC520
UC Guy
Hello guys,
I have an issue I can't resolve with the CUE on my UC520. We have been having problems lately with users mailboxes being busy or in use. I am having to go into the CUE and unlock mailboxes to free them up. it is happening more and more often. It is happening on our GDM as well. I have involved TAC on it but could not get a answer on what the cause is. Any suggestions?
2 Accepted Solutions
danplacek
Level 4
Level 4
1. Reboot CUE (this resolves this issue 95% of the time)
2. Upgrade firmware if not on the latest. (Be sure to do a full data/config backup and also a backup of the text configuration -- CUE upgrades have blown up on me more than once)
Also, are you using IMAP? IMAP has some weird bugs that can cause this as well.
David Trad
Hi Lewis,
I dont suppose you can do a debug on the SIP connection or the Dial-peer to the users mailbox for us could you?
I suspect that the SIP connection is not going through the clearing process properly and there is a hung session, sometimes this can be fixed by altering/changing the SIP dial-peer to the CUE to be more aligned with what it is expecting.
But as the suggestion above states, normaly a reboot can flush this, but it probably wont take long for it to return, and an upgrade of the system might resolve it, but it could also introduce other problems if your configuration is not sound and having problems.
Cheers,
David Trad.
davidtradconsultinggmail.com
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
23 Replies 23
danplacek
Level 4
Level 4
Hi Daniel,
thanks for the response. I have done the reboot a few times already and it keeps coming back. I am looking into the firmware, however, it was recently upgrade a few months ago. This client is not using the IMAP feature. it appears to be as if there are to many people on at the same time. However their call volume has not really changed. I will post some config info and some debug, however, I am logging in remotely so it is hard to simulate when no one is there. thanks again.
David Trad
Hi Lewis,
Cheers,
David Trad.
Hi David,
I will post some config info shortly and you can tell me what you think. Thanks again both of you.
Lewis
Here are a couple of the Dial Peers.  I can't do the debug yet, but will get some today. I hate to over tax the system with debug.
dial-peer voice 2001 voip
mailbox-selection last-redirect-num
description ** cue auto attendant number **
translation-profile incoming MainNumber-AA_Called_25
translation-profile outgoing PSTN_CallForwarding
destination-pattern 3098
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
voice-class sip outbound-proxy ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 2012 voip
description ** cue prompt manager number **
destination-pattern 3097
b2bua
codec g711ulaw
no vad
Hi Lewis,
Can you please change those dial-peers to look like this:
"dtmf-relay rtp-nte"
I wont comment on the other stuff as I don't know enough about your configuration, I can make assumptions but that would be harmful with not knowing more information.
But make that change as I suspect it will be more suitable, if it doesn't work then it is easy to revert back.
Cheers,
David Trad.
David:
That will only work if CUE is configured to match, no?
Assuming that DTMF to CUE currently works, we can infer that it is configured to SIP-NOTIFY, not RFC2833.
In any case, SIP-NOTIFY is a valid method for DTMF... it really shouldn't cause any problems.
Lewis: You mention two different error scenarios... what are the exact error messages you are getting?
-Dan
HI Daniel,
I don't know what the error message is, the users are complaining that it rings busy when they check voicemail.
Interesting, I had assumed you were getting the "Mailbox is in use, contact your administrator" message.
A busy tone is something else entirely.
Have you been able to capture a SIP trace while this is happening?
here is another config for the integrated module.
interface Integrated-Service-Engine0/0
description cue is initialized with default IMAP group
ip unnumbered Loopback0
ip nat inside
ip virtual-reassembly in
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
I also stated that they were not using IMAP, however, I may be wrong on that. I have noticed a few mentions about IMAP in the config.
ok guys, here it is. The final answer.
After going through the CUE config, we noticed that the IP address on the CCN Subsystem SIP was wrong.
ccn subsystem sip
gateway address "10.1.1.1"
end subsystem
the IP should have been 10.1.10.2
ip nat inside
after changing this, the system has worked so far. Crazy thing is, this has been like this since the beginning of the year when cisco tac helped us to rebuild the CUE when it went down before. Anyway, seems to be fixed now, I hope. I will keep you posted if it changes. thanks for all your help.
by the way, Dave, I gave you points because you were correct on it being an issue with SIP and it getting hung. thanks again for all the help both you guys gave me.
OK, guys. issue never went away like suspected, just less frequent. I am having to unlock users daily. If  I wait for about an hour or so, they free up themselves. weird. I know we have a "maxsession=6" and I was wondering if that could be the issue. if it is, how do we upgrade this or are we stuck with 6 sessions?
The number of sessions to CUE is fixed on the UC500 platform.
Have you checked "show ccn call application" while this problem is occuring?
Also, what specifically are you doing to "Unlock" mailboxes?
