Hi Everone,Has anyone tested a Plantronics headset with the new SPA504G ??? if so which one works or does anyone know of a compatable headset with these new SPA5XX IP Phones.Many ThanksJ
I wanted to share an issue I ran into, that took me a while to figure out. Too sumarize, I had no issues installing and accessing all VMs for CUCM, UC, and CUPs as you normally would. I had them configured with a 7 character application pw, which i...
Hi I got fax to email working on UC500, but the default format for the attached document is .tiff format, is there a way that we can change the attachement file t o.pdf format in CCA ?
We have about 5000 devices (SPA2102, WRP400, SPA8000, SRP521 and SRP521-U). Fax transmissions are generally OK but there is a little percentage of failed fax.Tipically faxes are handled via Cisco NSE 192 events. We studied many traces and we observed...
Hi,Is it possible to have a SPA2102 (FW 5.2.13) automatically hangup after a call has ended, or at least not play the off hook noise?We have it connected to specialized intercom phone, the guest dials a feature code to dial phones within the office, ...
I am about to put in a UC560 for a client and she just told me that she wants to be able to basically forward a voicemail from her voicemail to some other user voicemail on the system. She says that if someone leaves a voicemail for someone in the wr...
Hello Friends;Im working on a system and I need to make dail-up connection over voip devices, I'm using Cisco SPA112 for two point and DailUP server is Cisco 2821 have 16lines. Its a special project but Im having diffuculties about Cisco SPA112 confi...
Hello,In our VoIP environment we are using SPA504-phones.The problem is when a anonymous call is transferred the trace sees this as "Anonymous via accountA", but it is displayed as "Anonymous" on the phone.Is there a setting to see "anonymous via acc...
Hi,I am managing many spa5xxg phones (>2k) with a Thomson Cirpack call center and interception is not working well.My setup :"ServerType" set on 'Asterisk' or 'RFC3265_4235'."Attendant Console Call Pickup Code" with '*11*#'."Unit 1 Key 1" with 'fnc=b...
Hi there,I have Cisco SPA504G IP Phone.I am using it with my enterprise server.Now, when I use the group call pickup feature using the contact sesitive soft key (the one which uses the temporary subscription on server to get the details of the ringig...
Main site with a UC540 anda remote site for a teleworker with a SPA525G2VPN server ans SSL VPN configured on the UC540The remote phone connect to the uC540 via VPN no problemNow I need to connect the remote PC to the UC540 so the remote Pc can access...
I'm having problems loading firmware 5.2.12 onto my SP2102-R ATA. I have my laptop PC running Windows 7 directly with an ethernet cable from my laptop to the ethernet connection on the back of the SPA2102. I run the .bin file and In order to get th...
HelloThere are a atas186 who was registered to a CUCM version 6.1,the call manager was migrated to version 8.6 but now the second por when a call is answered immediately when give a fast busy tone, the first port works perfect, and i have changed man...
