10-23-2013 10:51 AM 03-21-2019 07:52 AM 更新
I had an SBSC engineer tell me at some time recently that there's some issue with certain software versions of CUE where it can suddenly experience corruption meaning data loss. He said to upgrade to 8.6. Can someone tell me which versions were affected and maybe more info about this issue? I have a client with a UC500 that experienced some issue about every three months like this and we've had to rebuilt CUE at least once (pain in the neck) and I need to know if upgrading would possibly fix the issues. If you can provide the affected CUE versions as well as Software Pack versions, that would be helpful, and of course in which versions it was corrected.
10-23-2013 11:13 AM
As the Cisco engineer correctly indicated, you need to update to latest without doubt.
10-24-2013 10:47 AM
This issue is fixed in CUE version 8.6.5. That version of CUE is included in software packs 8.6.1 and newer.
Software Pack Matrix: https://supportforums.cisco.com/docs/DOC-9827
Please note, this issue only affects UC560s.
-john
エキスパートの回答、ステップバイステップガイド、最新のトピックなどお気に入りのアイデアを見つけたら、あとで参照できるように保存しましょう。
コミュニティは初めてですか?これらのヒントを活用してスタートしましょう。 コミュニティの活用方法 新メンバーガイド
