Dailing out using Call Connector Toolbar
holguie81
How do you get the 9 to be addeded automtically when dailing out using Call Connector Toolbar?
Yes it is handled from that dialog... if you goto the "Advanced" tab under the "Phone and Modem" window you should see "Cisco Unified CME Telephony Service Provider". The "Dialing Rules" tab is where outside-line prefixes are specified.
I have set this up on dozens of PC's -- that is definetely where it needs to be configured.
The one other thing to check -- if you are dialing from outlook, make sure outlook is set to use the Cisco adapter. (This is configured in the "Dialing Options..." menu accessed from the Outlook "New Call" window)
7 Replies 7
danplacek
Level 4
Level 4
Under modem settings in the control panel you can specify a digit for an outside line.
The modem setting are setup, but I do not think the call connector is treated as modem. It belive the connects to the UC via IP using SSCP. I am not sure how the call connector connects but i would assume it would be the same.
Worked like a charm thanks!
Hello, I'm having a problem. I configured on Phone and Modem windows to add 9 on the dialing rules and selected cisco adapter on dialing options in Outlook. So, it's actually working in Outlook contacts, automatically appends the 9 before the number. However, the problem is on IE toolbar or direct dialing when entering a number in the call connector window is not appending the 9 before the number as it does in Outlook, so is not dialing out. Is possible to fix this? Thank you
Daniel,
Thanks for clarifying this I will check this out and let you know how it goes.
I tried setting the 9 but it does not add the 9 to the number on Outlook,  I finally had to add a 9 before dialing out.
