02-24-2011 06:28 AM - edited 03-21-2019 03:43 AM
I am trying to work with a SMTP server that uses the default-from email address as authentication. This is for a UC540.
I tried logging into the CUE CLI and typed the following commands:
ccn subsystem email
default-from customer25@abccomany.com
end
It took the commands without error. When I run the show ccn subsystem email command, nothing comes up.
The UC540 is on software pack 8.1.
Is there another way to do this?
02-24-2011 02:16 PM
I make this change from the web and have never had a problem. (10.1.10.1-default CUE)
02-25-2011 05:48 AM
Could you be more specific to what section that is in?
02-25-2011 08:34 AM
Here is a screen shot of the Default "From" Email Address Settings in System>Fax Settings, but you are setting up SMTP, so you will want to change System>Domain Name Settings. Attached is a screenshot of both places on a newer system. Same place if you have CUE 7.x.
