does spa9000 compatible with spa504G?
wayne.fong
SPA94X series is end-of-life. I recently purchase SPA9000 and waiting for SPA504G. Does SPA50X fully compatible with spa9000. I have a bit concern since I saw one post here that it has problem.
nseto
Level 6
Level 6
Yes, it is.
You can see in the SIP tab of the spa50x series that it has the parameters; Linksys Key System, Mulitcast Address and Key System IP Address to fully function with the spa9000.
Thanks nseto
CTRLITINC
We have tested the SPA504G extesively with the SPA9000 and have running internally as well at a few client sites. Installed a few last week w/o a glitch.
When you plug it in it should work w/o doing much of anything.
HTH,
Steve Wofford
Call Ctrl Call Manager for:
SPA9000-SPA900-SPA400
