Dropped Calls on UC520
ReidJones
We're having major issues with our UC520 dropping calls, usually when the call is transferred for the call queue.  Could someone please recommend the logs I should run to find out the reason.
7 Replies 7
paolo bevilacqua
Which exact IOS are you using ?
Version 15.1(2)T4
Please update to latest and check again.
Is there a fix to this issue or a similar issue in the update?  I'm downloading software pack 8.6.1 now.
Exact same issue on the latest software pack.  What tests should I run.
Can you tell the exact conditions under which it happens, as you first post is not very clear about that.
David Trad
Hi There,
What are the lines the incoming calls come in on? Is it PSTN/ISDN/PRI or SIP? This will determine what debugs to run.
Also you need to be as descriptive as possible with your issues, give us some scenarios as that can help as well.
Cheers,
David Trad.
Sent from Cisco Technical Support Android App
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
