11-20-2012 12:03 PM - edited 03-21-2019 06:38 AM
We're having major issues with our UC520 dropping calls, usually when the call is transferred for the call queue. Could someone please recommend the logs I should run to find out the reason.
11-20-2012 01:54 PM
Which exact IOS are you using ?
11-21-2012 03:43 PM
Version 15.1(2)T4
11-21-2012 03:57 PM
Please update to latest and check again.
11-21-2012 04:09 PM
Is there a fix to this issue or a similar issue in the update? I'm downloading software pack 8.6.1 now.
12-06-2012 11:48 AM
Exact same issue on the latest software pack. What tests should I run.
12-06-2012 12:07 PM
Can you tell the exact conditions under which it happens, as you first post is not very clear about that.
12-07-2012 02:18 PM
Hi There,
What are the lines the incoming calls come in on? Is it PSTN/ISDN/PRI or SIP? This will determine what debugs to run.
Also you need to be as descriptive as possible with your issues, give us some scenarios as that can help as well.
Cheers,
David Trad.
Sent from Cisco Technical Support Android App
