HELP: UC520 and CCA
yarusemi1
I am having an issue getting the IP address to connect to CCA.  Anyone know how to get the IP address for CCA?
Use serial console to configure IP.
According login credentials - read password for uc500
Dan Lukes
Your LAN administrator knows what IP address can be used in your network. So ask them, he will assign a free one to you.
I got this router on eBay a few months ago.  I had to factory reset it.  I am having issues finding the ip username and password for CCA.
this is old.  I found out how to do it.  Thank you.
