02-14-2017 11:32 PM - edited 03-21-2019 10:38 AM
Hello there,
i know the use of Linksys PAP2T devices but somewhere i've read that i can transfer landline (through lan) with someway...
Is it possible and how ?
Thanks in advance
Solved! Go to Solution.
02-14-2017 11:57 PM
With PAP2T ? No way as far as I know. It have just two FXS ports, but no one FXO port. Thus you have no plug to connect incoming POTS analog line to.
Read What is the difference between the FXS and FXO voice cards to become familiar with FXO versus FXS port difference.
02-14-2017 11:57 PM
02-15-2017 02:03 AM
Thanks for the answer..
Yes i know that have only FXS... but i ve read something (can't found it) with firmware that are compatible with PAP2T and make it work as server fxo, do you know something ?
02-15-2017 03:44 PM
Confirming Dan Lukes' post, you have to have an adapter with an FXO port. The PSTN landline uses an analog signal, the local network cabling uses a digital signal. They are completely different. You need an adapter like the SPA3102 which has an FXO port and can then forward the call using a voip protocol thru a LAN to a distant PAP2T.
02-15-2017 11:37 PM
You have totally right... you and Dan..
Thanks for the answers!
