There are some issues with ata 190 2FXS 1. Often(Maybe once every two weeks.), the connected fax doesn't hear the dial tone and becomes useless. This is a strange symptom that resolves after 30 minutes without any action. Or, rebooting the equip...
Hello!Look this document:ADMINISTRATIONGUIDECisco SPA100 Series Phone AdaptersSPA112 and SPA122http://www.cisco.com/en/US/docs/voice_ip_comm/csbpvga/spa100-200/admin_guide/SPA100_AG_OL-25117.pdfPages 95-96: Example 1:*1xxxxxxxxxx<:@fwdnat.pulver.com:...
I am using firmware 1.3.2.I am trying to use an analog telephone with the Line 1 port to make outbound calls via Voip or PSTN. I cannot get the outbound calls to route via PSTN at all...even if using Line 1 Dial Plan (*xx<:@gw0>|xx.<:@gw0>)PSTN calls...
I'm trying ( first time user ) to connect a SPA 112 to a telephone system that supports SIP telephone extensions.I have a half dozen of these to install for a not-for-profit with off site group homes for handicapped children.Does anyone have a "cheat...
Hello,CUCM 11.0.1... Unity 11.0 1... Gateway 4331I have a phone number that is answered by unity Call handler that works. This is from the Router active call: OriginalCallingNumber=xxxxx5977OriginalCalledNumber=xxxxxx2958OriginalRedirectCalledNumber=...
So I have looked around but cannot find firmware update for UC320W. I found this https://community.cisco.com/t5/small-business-support-documents/uc320w-firmware-release-information/ta-p/3295527 but all the lings are broken. Having issues with voicema...
All of my phones have been 7960's to date but decided to add a 7970G. However I cannot get hte phone to pair up with the UC540 - instead am just getting flashing green line buttons. Have checked the CCA and it would appear that our installer may ha...
I am using my system for one SIP line and also PSTN. Everything is working fine except when I call another number then when I need to send DTMF tones (for options or phone extensions) the DTMF signals are NEVER recognised. Is there a standard setup f...
Is it possible to load the phone book directly from the configuration file of the cisco Phone spa504g?è possibile caricare la rubrica telefonica direttamente dal file di configurazione del Telefono cisco spa504g?
We have new Cisco 8861 phones programmed with voip.ms set up and working, however the DND mode does not turn the BLF indicator red. Is there a setting that needs to be changed to enable this? I've found the following documentation from Cisco, but as ...
We just got Cisco 8861 phones and I am working on setting them up, I can receive and make calls no problem. However when trying to set up the BLF fields I keep getting a flashing or solid amber light. We are using the phones with voip.ms and I have c...
Hello.. I rolled out a bunch of SPA122 for my customers.. A few of them are reporting that they are getting echos on the caller side. Caller is reporting they can hear a delayed echo of there own voice. I've made sure echo cancellation is on and I've...
I have a customer who is using a Spa 122 to connect to our Voip network. On inbound and outbound calls the far end party hears themself in an echo. We have tried adjusting the echo cancellation, Gain, settings for the fxs ports, and adjusting the fir...
