How do I configure the GW on a UC520
service
                   I have used the Config Wizard to set up the UC520 but I am having DNS issues when trying to gfet out to the internet. When I check the System Status it shows "None" under the Gateway column. Under Routing/Internet Connection/FastEthernet0/0 Modify Internet Connection I have entered the Default Gateway. Could some one tell me what I need to do to configure the outside gateway?
Naum Vitanovski
you will probably need to configure a default route on the UC520 statuc routes:
ip route 0.0.0.0 0.0.0.0
also have to configure dns on your where you have entered the default gateway, in internet connection. put the value 8.8.8.8.
also make sure you can ping the default gateway from your uc520
cheers,
Naum
Thank you for the quick reply. When I go to Static Routing /Add Stactic Route I do the following
Destination/Network IP: 0.0.0.0
Network Mask:              0.0.0.0
Enter Gateway IP
Gateway IP or Outgoing 75.132.192.1
OK
I get the following message:
Warning
The gateway IP address you entered is not routable
Make sure that you entered the IP address correctly.
Non-routable IP addresses are not listed in the static route table
Do you wish to continue?
Just so I can continue to assist you, can you give me your uc520 ip address.
service
Vlan 1 is 192.168.10.1  255.255.255.0
Vlan 100 is 10.1.1.1      255.255.255.0
