12-03-2010 01:56 PM - edited 03-21-2019 03:20 AM
I have a UC520 configured with a SIP Trunk that handles all inbound and outbound calls. I recently added a pstn line for auto failover. Soemtimes when a user makes an outbound call it picks up the pstn line. This line is used primarily for outbound faxes, but not inbound. i want to disable all outbound calls on the line from the uc520.In the outbound dial plan all calls are configured for sip only. Any suggestions?
12-03-2010 04:21 PM
Hi Barry
You could use COR, supported via CCA and CLI
more details: http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
Victor.-
PS: Please rate if the post was helpful
12-06-2010 05:10 AM
In CCA, you can go to "outgoing dial-plan", and set all outbound dial-peers to use SIP only when configuring the priority. No outbound dial-peers to FXO ports = no outbound calls to FXO ports.
Adam Compton
12-06-2010 06:59 AM
I tried that already, In fact I had the settings at "sip only" since I got rid of the pstn lines, a year ago. I am trying to add a fax line as incoming only, to use it as a failover for sip, since the fax does not accept inbound calls anyway. The problem is that occaisionaly when someone makes an outbound call it picks up the pstn line, and sometimes you hear an outbound fax. I was looking for a way to either completely disable outbound pstn or use a different access code, such as "8" to activate outbound pstn and keep "9" as the access code for sip.
12-06-2010 07:12 AM
Sounds like you may still have some dial-peers for outbound FXO in the configuration, even if they don't show up in CCA.
