how to give preference to fxo ports?
shabeerpulikkal
I have 12 pstn lines coming to my UC 500.
out of these 4 lines are from PBX. Now whenever i make a call to outside i want the line connected at port say 0/3/0 should be used first,the the line at port 0/2/0 should be used secondly. I have to give preference to the fxo ports. Kindly help me in this case..
Steven Holl
There is a preference value under the dial-peer which allows you to do this.  In CCA, I think the dial-peer preference is configured under the trunk group, but I'd have to open CCA to verify exactly where that is set.  The feature was added to CCA 2.0, though.
Brandon Buffin
You can do this in CCA under Outgoing Dial Plan or in CLI by using the "preference" command on your dial peers such as:
dial-peer voice 1 pots
destiation-pattern 9T
port 0/1/0
dial-peer voice 2 pots
destination-pattern 9T
preference 1
port 0/1/1
The default preference is 0 and a lower preference means a higher priority. In the case above, calls are sent first to port 0/1/0 and then to port 0/1/1.
Hope this helps.
Brandon
Steven DiStefano
Check out the Technical Ebablement Lab in this community documents section for fxo trunk groups.
Steve DiStefano
Technical Solutions Architect - Partner Sales, USA
Cisco Systems
7025 Kit Creek Road
Research Triangle Park
North Carolina, 27709
1.919.392.6219
sdistef@cisco. com
www.cisco.com/smb
