ā01-16-2013 10:52 AM - edited ā03-21-2019 06:50 AM
my E1 provider wants to see 10 digits from my be 3000, but saw only 4 which is my internal line number.
what should i do to send 10 digits???
sorry for my stupid question.
i'm new in phone tec)))
ā01-16-2013 07:52 PM
Hi Evgeny,
It should not be 4 digits that are sent out of E1 Interface. It should atleast be office-code+subscriber number, which is typically more than 4 digit. For example in NANP, it is 7 digits. So I have some questions for you:
1) Which country is this deployment in?
2) Is it a local or a long distance call?
3) What number does the user dial?0
Generally, you can change number of digits that gets sent out on the E1 interface on PSTN Connection - S0/SU0-.., Advanced Setting - Outbound call routing
You need to set it to Manual mode, click Edit and edit patterns in the new window that opens up.
ā01-16-2013 10:22 PM
1) Russia
2) Local call
3) I create that template for outbound call routing
my isp said that 1002 went from E1 flow.
I can call different outside users (mobile phone or landline phone without any problems))
ā01-17-2013 08:56 PM
According to the template above, called number should be 11 digits starting with 8. If that is not the case, please enable detailed traces, make a call and send that.
ā01-22-2013 12:32 AM
yep. it was a mistake but after changing to 10 result was the same. (SP see 4 digits number)
later i send you my diag file=))
