How to setup Spa2100 after WRT54GS
rahultakur
I have SIPURA SPA2100 and broadband router WRT54GS framewire v 7.5 , ata cordless phone .
First Approach: for me  not worked
I have contected broadband modem ethernet cable to WRT54GS router. from WRT54GS LAN I contected to WAN of SPA2100.
and used another LAN of WRT54GS router to PC. and attached SPA 2100 phone jack 1 to my ATA phone.
After this i  dailed " **** "then 110# , opened the browser tab and typed http://<Ip address> . after here i cannot open the web interface of SPA2100.
But I can open WRT54GS router web page.
Second Approach:not worked
I have contected broadband modem ethernet cable to SPA2100 adapter WAN. from SPA LAN I contected to WAN of WRT54GS router .
and used  LAN of WRT54GS router to PC. and attached SPA 2100 phone jack 1 to my ATA phone. But here I hardly conect to internet.
After   dailedly " **** "then 110# , opened the browser tab and typed http://<Ip address> . though i cant access the web interface of SPA2100.
Third Approach : not worked
connect Modem ethernet to WRT54GS router WAN,then conneted ethernet between WRT54GS router  LAN and SPA2100 WAN .
and then plugged cable to  PC LAN to SPA2100.
After several retry i can get Limited internet connection.  though cant access the SPA2100 web interface.
I tried all process but I am not able to connect SPA2100.
Diconnected firewall while doing these steps.
.So, 1. can you please suggest me what are the appropiate steps should be take to configure.
.      2. Do i need to upgrade the Firmwire in my WRT54GS router r? if yes, how to upgrade and what is that file that I have to  download?
Appretiate for any suggestions.
With ragards.
Rahul
Tomas Chott
at first, try this
Q. I want to use a different computer to access the administration web server.
The address I entered did not work.
A. Use the Interactive Voice Response Menu to find out the Internet IP address.
Follow these steps:
1. Use a telephone connected to the Phone 1 port of the ATA device.
2. Press **** (in other words, press the star key four times).
3. After the greeting plays, press 110#.
4. Write down the IP address as it is announced.
5. Press 7932#.
6. Press 1 to enable WAN access to the administration web server. (maybe restart adapter)
7. Open the web browser on a networked computer.
8. Start Internet Explorer and enter the IP address of the ATA device.
and for check web port "Press 170#"
Tomas
5 Replies 5
Tomas Chott
at first, try this
Follow these steps:
5. Press 7932#.
Tomas
hello toma
I can go into the sipura web interface page but its asking admin username and password.In Input alert box its says "A username and password are being requested by http://172.16.0.1. The site says: "spa admin"
I bought SPA2100 from Ebay.And the previous owner provider was broadvoice.com  and mine is voiparound.com.
What should i do to get  username and password. Can i Reset  to linksys default username and password .if yes then  how can i do it.
Rahul
Hello Rahul,
1/ maybe have SPA products in "R" version and this you cannot reset to factory defaults, only use with last provider
2/ if you have free not "R" version you can reset by enter admin menu **** and the press "73738#"
but adapter can be blocked for reset via Voice Menu
Tomas
If it is " R" version then it is no use for me.So, I have to buy new one.
Could you please suggest which phone adapter is good and effordable for home purpose.
Thank you
Rahul
Dear Sir;
Either PAP2T or SPA2102 would make the deal.
SPA2102 provides following features not supported in PAP2T:
- Support for simultaneous G.729 codecs
- Support for T.38 fax.
- Support for basic routing and bridge functionality
Alberto
