How to trim the first digit of called number?
Pavel Teplov
Level 4
Level 4
Hello.
BE 3000 (8.6.3), Russian pack
Internal GW (E1 PRI) conected to PSTN.
For calls (local,mobile, toll free, long distance) the operator require only pass 10 digits (format is {area code}{local number})
By default the BE 3000 pass 11 digits as the first digit is '8'.
Necessary to remove the '8' before pass a call to SP.
How to do this without using the external "converter"?
Pavel
sanjsinh
I do not think this can be done using 8.6.3. However, in 8.6.4, there is a feature called Called Party Transoformation which can be used to trim the leading 8.
And ISDN configuration also cant be use?
Configurable ISDN parameters on PSTN connection page does not help with trimming the leading digit which gets sent out to the PSTN trunk
