How to use SNMPv3 in SPA122 ATA?
Alex Wilson
How to use SNMPv3 commands with SPA122 ATA ?
SNMPv3 support is enabled in SNMP management settings.
Did not find any examples of SNMPv3 commands for SPA122.
Kevin tech
Same problem. Can anybody show a few examples of SNMPv3 commands for SPA122?
SNMPv3 is similar to SNMPv1 - you can retrieve or set value of particular OID and you can list OID tree.
You need a SNMP client to talk SNMP protocol. Thus what you mean "example of SNMPv3 command" ?
OK, I find some description of SNMP administration settings in Administration Guide.
SNMPv3 syntax is much different from v1/v2, as there is used Authentication, Privacy, EngineID Identifier, therefore any sample SNMPv3 command with default settings (that set in SNMP tab) would be helpful.
Where to download a full set of MIB for SPA122 OID tree?
SPA122 is SNMP server. Commands are sent by client.
Follow the documentation of SNMP client of your choice.
SPA122 is not SNMP client. It send no SNMP commands, thus asking "example of command" is meaningless.
May be someone else will understand your question and will answer.
No such package is available (as far as I know). If you are interested in MIB related to particular OID, disclose the OID in question.
