Hypothetical Flash Upgrade
jaydien1358
Level 3
Level 3
Ok, so I have a hypothetical scenario that I would like to ask some procedural questions on.
Lets just say that someone was going to go against Cisco's advice and guidelines to be a complete rebel and try to upgrade their very, very small 128MB flash card in theri UC to a 2GB flash card.
What would be the propper procedure in doing so? :)
How should one format the card and get the files onto it, etc...
Thanks!!!
-Brian
You could use a CF reader and move the files on your PC using Windows Explorer. But the fact is that we do not support or test any other hardware.
Marcos
Marcos
jaydien1358
Level 3
Level 3
10-4
Thanks!
-Brian
