06-29-2012
09:14 PM
- last edited on
03-25-2019
11:02 PM
by
ciscomoderator
UC540
SP 8.6.0
Can the Intersite Dialing Prefix be different for the sites?
For example, can Site 1 use an Intersite Dialing Prefix of '4', and Site 2 use an Intersite Dialing Prefix of '7'?
Or does the Intersite Dialing Prefix have be '4' for both Site 1 and Site 2 (or '7' for both Site 1 and Site 2)?
I do not see that specified in the Multisite Documentation, so please no Cuts and Pastes please.
Thank you
Solved! Go to Solution.
06-30-2012 09:38 AM
You would then just replace
incoming called number 43...
with
incoming called number .
Then make sure that the voice translation-rule referred under multisiteinbound correctly strips out any possible prefix.
An alternative is to strip prefix and site id at source, again using voice translation profile and rule.
06-29-2012 11:40 PM
Hi Clifford,
The multisite steering digit is going to be unique for each site. For instance if I am at site A trying to call site B I am going to dial 8… to reach the site B extension.
06-30-2012 07:33 AM
Hello Jason,
I do not know what you mean by the Multisite Steering Digit.
To use the terminology that Cisco uses, there is an Intersite Dialing Prefix. This digit is used to inform the UC500 that a MultiSite Call is going to be made. I am wondering if this digit has to be the same at all sites.
I am not talking about the Site ID, which I know does have to be unique for each site.
Thank you.
06-30-2012 07:40 AM
At least with manual/CLI configuration, you can have any site using anything want, to do anything you can think of, multisite calling or other.
06-30-2012 09:32 AM
Well, I found out that the Intersite Dialing Prefix has to be THE SAME between all sites (I am not talking about the SITE ID).
I was not able to find this statement in any of the Cisco Documentation, including the 'Cisco Configuration Assistant SBCS Administrator Guide, Site Management, Section 16.
Here is the CLI output of a UC500 that has been configured for Multisite Site 'Broadway':
dial-peer voice 2100 voip
corlist incoming dial-internal
description ***CCA*INTERSITE inbound call to Broadway
translation-profile incoming multisiteinbound
incoming called number 43... <-THIS INDICATES THAT THE UC500 IS EXPECTING A CALL FROM SOMEBODY WHO DIALED '43...', WHICH MEANS THAT THE CALLER HAD TO USE THE INTERSITE DIALING PREFIX OF '4' WHEN THEY CALLED.
06-30-2012 09:38 AM
with
06-30-2012 11:42 AM
Excellent
Thanks Paolo!
06-30-2012 11:51 AM
Hi Paolo,
If I replaced' incoming called number 43...' with 'incoming called number 73...', to allow calls to come from the site that uses '7' as the Intersite Dial Prefix, then I won't be able to accept calls from sites that use '43' (that use '4' as the Intersite Dial Prefix'
To offset this, could I create a second 'incoming called number' statement under my dial-peer voice 2100 voip command?
Or maybe I could create a second dial-peer....
I am used to using CCA, so I am not a Voice CLI expert.
thanks !
06-30-2012 12:48 PM
No need to create additional DPs, read post above.
Thanks for the nice rating and good luck!
