<CiscoIPPhoneExecute> what command for dial ext line 2 on spa504g
hugokanner
I'm trying to  dial on line 2 (ext2)  on a spa504g (4 lines)   with C#.  I have to account sip registred on the phone . How can select the  line 2 with my command xml ?
<CiscoIPPhoneExecute><ExecuteItem Priority="0"  URL="Dial:1546" /></CiscoIPPhoneExecute>
Here is my code :
 WebRequest request = WebRequest.Create("http://192.168.1.17/CGI/Execute");
        request.Method = "POST";
        string postData = @"XML=<CiscoIPPhoneExecute><ExecuteItem Priority=""0""  URL=""Dial:1546"" /></CiscoIPPhoneExecute>";
           byte[] byteArray = Encoding.UTF8.GetBytes(postData);
        request.ContentType = "text/xml; charset=\"UTF-8\"";
        request.ContentLength = byteArray.Length;
        Stream dataStream = request.GetRequestStream();
        dataStream.Write(byteArray, 0, byteArray.Length);
        dataStream.Close();
        WebResponse response = request.GetResponse();
        Label1.Text = ((HttpWebResponse)response).StatusDescription.ToString();
        dataStream = response.GetResponseStream();
        StreamReader reader = new StreamReader(dataStream);
        string responseFromServer = reader.ReadToEnd();
        Label1.Text += responseFromServer;
        reader.Close();
        dataStream.Close();
        response.Close();
thanks
6 Replies 6
Aaron Harrison
You would first send a 'Line2' message to pick up line two, and then send the dial command.
XML=<CiscoIPPhoneExecute><ExecuteItem URL="Key:Line2"/></CiscoIPPhoneExecute>
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Hi, Aaron
How to send "Dial" and "Key" in a single post-query
Thanks.
Just put in multiple 'ExecuteItem' elements.
I would submit them separately though to ensure the order of the actions.
Aaron
Here is a sample of my query:
Host: 192.168.1.246
Accept: /
Content-Type: text/xml; charset="UTF-8"
<ExecuteItem Priority="0" URL="Dial:124"/>
<Enter>
when sending a POST query, is performed only one.
Is it possible for a query to execute in sequence 2 URL ?
Maybe you need some form?
Thanks.
Why not submit multiple requests? This will give you more control over sequencing.
Aaron
Re posted to to XML Phone Applications.
